jeroenvans
Berichten: 1907 Lid geworden op: 02 apr 2007, 15:11
door jeroenvans » 15 feb 2009, 23:12
PD schreef: whats the sice of you piston?
Flika schreef: Yes it's going to be 48mm bore, tuned YG1 barrel and piston, 22mm carb.......................
Flika
door Flika » 16 feb 2009, 10:02
Spec at the moment is 47mm bore and 21mm carb seems to be working Ok
door jonnotje » 20 mar 2009, 19:26
have you already driven with your tuned fizzy?
Flika
door Flika » 02 apr 2009, 20:27
Yes I've been riding it and putting some miles on the clock and have done some re-working to the ports, I've been using a standard cylinder head while the other one was being machined, it came back today. Got to wait another week or two then it's back on the dyno and this time I'll take some video. This time hopefully get the 12hp
Here's a pic of the modified head
door edje » 03 apr 2009, 21:47
looks good
wat topspeed does it have??
(3 years ago since my last englisch lesson:oops : )
door Triforce » 04 apr 2009, 11:01
woow a very high pressure head
nice work on that
i hope it will work and that it wont run a hole in the piston
Flika
door Flika » 05 apr 2009, 22:19
Compression is set at 13.5:1 with 0.7mm of squish, hope it works out ok.
Flika
door Flika » 16 apr 2009, 10:04
Mission accomplished
<img src="http://img10.imageshack.us/img10/7867/dscf1469m.jpg" width="800">
<img src="http://img10.imageshack.us/img10/8650/dscf1470k.jpg" width="800">
door YamaSam » 16 apr 2009, 10:10
congrats man!
(now do it wit 40mm bore
miran72
Berichten: 536 Lid geworden op: 29 okt 2006, 23:09
door miran72 » 16 apr 2009, 10:54
Wat is er te feliciteren hier, ik kan die aan die grafiek moeilijk lezen wat nou de prestaties zijn die grafiek staat erop in posterformaat ik denk
60 m/ph
13000 toeren
15 bhp
heb ik datgoed?
door mpro09 » 16 apr 2009, 10:57
klik erop of lees de getalletjes links
looks very good
congratulations!!!
Flika
door Flika » 16 apr 2009, 15:18
miran72 schreef: Wat is er te feliciteren hier, ik kan die aan die grafiek moeilijk lezen wat nou de prestaties zijn die grafiek staat erop in posterformaat ik denk 60 m/ph 13000 toeren 15 bhp heb ik datgoed?
Those readings are the base settings for the graph
door Niels » 16 apr 2009, 16:50
Nice man!
Never seen a FS1 with 12bhp, until now
door jonnotje » 16 apr 2009, 16:58
Niels schreef: Nice man!
waar staat bhp voor
oh lama, ik lees ergens dat het pk is.. klopt dat?
Flika
door Flika » 16 apr 2009, 17:13
I wish I spoke Dutch
