Hellow from Germany
hcl2
Bericht door hcl2 »
Hi,
I think the main problem with Tanjas brake is that the caliper itself is not able to move anymore. Brake lines and main-cylinder seem to be ok. The Brake pads need to be renewed; they are oily since Marco (the german one) fixed a squeaking noise with break assembly paste :). I am not shure if the break piston ist moving perfectly, but befor the brake power was ok for a non-moving caliper.
So I need help in understanding "Oud type ophanging" in this FAQ
http://www.fs1forum.com/viewtopic.php?t=5293
The translation in google translator is very bad (at least for me).
I wonder how it is possible to remove the rubber/plastic parts and to get out the bolts...
Greetings, Jan
The caliper is suspended with 2 pins, behind 2 small rubbr plugs. They are threaded with M5 and should be pulled out. They can be really stuck, sometimes you need to hqeat the whole caliper and use a lot of force or make some kind of pulling lever. A crowbar or hammer with a block of wood can do the trick.
If you decide to also squeeze out the piston, pull the O-rings out, and clean the grooves in the caliper. There's a lot of corrosion that should be scraped out. Also clean the pits of corrosion in the O-ring. Don't worry if the O-ring is shaped a bit oddly, I put back O-rings that really looked funny, but didn't leak. As long as the thick one isn't broken or torn, it will work. Don't use normal grease in the caliber, the rubber cannot have it and will swell. For any kind of lubrication necessary, use some brake fluid. Use dot 3 or 4 (they can even be mixed, avoid dot 5.
Put in new pads and put some copper grease on the back of the pads and everywhere were they make contact with the caliper, just avoid grease on the liner and disc themself.
Bleed the brake not only at the caloper, also make sure there's no air at the connection from line and reservoir. I always lossen them a bit, put a rag to protect tank and painted parts and squeeze out the air there. After this, if the line is still ok, the brake will do it's work like never before.
hcl2
Bericht door hcl2 »
Thank you very much for your advice.
Hopefully I will find time this week to follow your instructions. Till now I thought I had to remove some more parts of the caliper.
Except for the brakeline, I just described how to remove pretty much everything.
TanjaFS1
Bericht door TanjaFS1 »
great fighter.
and thx.
TanjaFS1
First accident survived. Take care the streets are slippery.
What happend??
marco schreef:What happend??
TanjaFS1
Wasnt with my eyes at the traffic.... had to stop quickly, rearwheel wanted to get ahead..im on the right side blue now and can hardly walk...fizzy is okay...i was a scutcheon for her.
Ohw :(
Lucky it's okay (okay enough) with you and your fiz.
TanjaFS1
Thank U from me and fizzy!
I can imagine it was a bit scary. :?
One moment you are riding, the other you are against the street.
Luckily everything is kind of alright!
TanjaFS1
the_destroyers schreef:I can imagine it was a bit scary. :?
right need one moment to get down...fixed than the front light and rode like nothin happend.....but now it hurts...cant go...
take care people the streets are slippery.
TanjaFS1
TanjaFS1 schreef:great fighter.
and thx.
