Uprated clutch
Geplaatst: 10 okt 2008, 22:53
door Flika
What do you guys use on highly tuned motors are there uprated parts available that work or is it a case of fitting a better unit?
Geplaatst: 11 okt 2008, 01:17
curious what this topic might bring up, a far as I know there are very little opions ..
there have been various brave atempts on the board here to modify the original part,
from two clutchhousings welded ontop of eachother and machined into a 'long' one with more frictionplates.
the righthand cover needed to be welded into a larger volume, leading to somewhat hideous exterior.
the 'light' tuneup consists of putting an extra metal plate in, and stronger springs.
with a little machining you can just get an extra frictionplate in.
the oil is also a good experimental terrain as you mentioned before
hope something comes up!!
Geplaatst: 11 okt 2008, 08:32
I use (like Yamasam mentions) an extra metal plate and clutchsprings from a Yamaha DT80.
Geplaatst: 11 okt 2008, 13:58
door Flika
Tombo, where does the extra metal plate go?
Geplaatst: 11 okt 2008, 15:57
what is "draaibank" in english?
an extra steel pressure plate fits already in there for another friction plate you come up short about 3mm
with a "draaibank" you can get a few mm of the back pressureplate(were the springbolds go into) and another mm from the inside of the basket
and than you have a 5 plate clutch without no other modifications
this is what ginofs1 made and it works perfectly
Geplaatst: 11 okt 2008, 16:04
door edje
draaibank:
