Inner rotor ignitions
Flika
Bericht door Flika »
Is anyone on here running one, if so what have you set the timing at?
Peter ( www.bromfietsallerlei.nl ) has one on a 'test drive fs1' for customers. Maybe you could send him a e-mail.
Andries
Bericht door Andries »
which make of inner rotor? a hpi?
Your timing depends of you have an ignition with variable timing (if it advances), or with fixed ignition timing.
Flika
It's the fixed timing system, I'm think it's the HPi one I'll check tomorrow.
Flika schreef:It's the fixed timing system, I'm think it's the HPi one I'll check tomorrow.
That are HPI one's yes, but they are quite expensive, like 200 euro's to 220 euro's
I thought the HPI's had a timing curve???
That's true, but the topicstarter isn't sure if it is an HPI ignition...
Flika
Didn't get to work today to check in fact I'm not sure there is a make on the box. It's definitely the fixed timing version though.
if its a fixed timing it just needs to be at 1.8mm
